Hello
My 1998 Ford Mustang base a/c is blowing hot air..I am using process of elimination to correct this problem..The clutch is moving smoothly during the recharge..I have located the low pressure switch and connector..I have switch out both and still no progress..which now leaves me with the high pressure switch on high side along with connector..Since the clutch and compressor are moving, I have eliminated the power connector on bottom of compressor...The next thing to do , I was told, to find the CCRM and fix the a/c relay...I located the relay, but I am not sure of the high pressure switch...Can you help me with any of those problems..???
