Hi all! At koeo, when the pump primes I get zero reading at my fuel pressure test gauge. Once running, at idle it sits at 20psi, under throttle sits at 20psi, vac line removed from fpr, 20psi, etc.
Along with this I have all the symptoms of low fuel pressure/running lean. Hard starts, difficult to keep running when first started. Misfiring/backfiring, bucking in low rpm, power falls off at high rpm, cel and codes 41/91. I have just replaced the fuel filter and fpr, and the problem persists. Before ordering a new fuel pump I’d like to be sure that’s the issue. I feel like it’s the last piece of the puzzle, but I want to be sure.
alot.
maybe I got lucky or I have it mixed up in my mind with the 225hp version.
