Fuel Fuel gauge not working.
91GTstroked
504
282
93
Hey guys, need some insight. Today it was 63 degrees so I decided to start the car. It hasn't run since the last week of October because winter storage. I also removed the battery.
I stored the car with a full tank of gas and the gauge worked prior to storage. The needle only moves a little bit. I had it running for about 20 minutes, with no changes. I even shut it off and restarted. I disconnected the battery for a couple minutes, same thing. Did the same thing you see in the video everytime. Maybe it will fix itself after I drive it a bit? Bad sending unit? Ground go bad from sitting?
Also, I was told from previous owner that installed these gauges that all of them are grounded together. All others work, and all light up. I was told that the fuel gauge is programmable and upon initial install needed to be calibrated. I hope that I don't have to do that everytime after it's been sitting for 4-5 months with the battery disconnected.
Don't mind the air bag charm from the module!
Any help is appreciated.
View: https://youtu.be/uJZHJIuDOXU
Here is a picture I took before starting the car up a few days ago. Showing that the fuel gauge was reading full upon putting it in storage.
