Need help got a non EGR intake I want to install on my 92 foxbody has anyone done it if so need input how to install it.
The computer is programmed for the IAT sensor temps in the manifold. I do not know if that makes much difference when you go elsewhere in the intake track, but they should not be the same.
As far as no boss to drill and tap, I have seen amazing welding repairs done to aluminum heads. Shouldn’t it be possible to weld up an area for a boss, grind it flat, then drill and tap like normal? Maybe even makecit thicker or wider than normal?
We drive on the left side of a vehicle, right side of the road , so the answer to that would be no.Staying with drum for now maybe in a year or 2 lol gonna look into it so I need to grab 2 right sides? Do you know year I need to look for?
