Leaded Fuel
Your catalytic convertors cannot handle it. Your heads have hardened seats so you do not need lead additives. Besides poisoning the environment so we have an excuse for brain damaged leaders :ack:, what is your hoped for benefit?
I am (just) old enough to have run leaded in a while in a pre cat car. It likes the octane boost from ethanol mix better. And it did not show valve seat wear when it needed a high mileage rebuild, although it had the gunk in the pan. It got hardened valve seats anyway.
I have an off-road H pipe, so the cats aren’t an issue. For me 100 octane leaded gas is readily available, for about what 91 (all I can get here at the gas station) costs. Lead has lubrication factors, but I not old enough to remember it being in mogas.
Just wondering if anyone has any experience with it.
Side note, precursor to being a politician is at least moderate brain damage, so I’m neither helping nor hurting.
  • Haha
Reactions: 7991LXnSHO
100 octane racing fuel is a different story than 91-93 premium, with or without lead. The lubrication was cushion for the valve seats. If you get things gas soaked enough to make a difference on piston rings or valve stems, it will have washed the oil off and there will be big problems. Fuel lubricating things in a 4 cycle engine is a marketing myth. Octane boosters often contained lead. But lubricating the engine from the gas tank is a lie.
If you have the compression, boost or other need for octane, more often fouled plugs is the only other downside I know of.
Reactions: Adizzle843
Hemirick, I agree about any modern engine, (except for the coating on spark plugs and possible toxic build up in the pan that’s probably less with newer oils). No big deal.
adizzle- history or TMI?
As far as using something needing lead, any aluminum heads better have been made with hardened seats. Iron heads without hardened seats do eventually recede. Tests by state patrols showed exactly which hard use conditions caused the recessed seats. (A weekend cruiser/antique plate car might never be an issue if you do not go on Power Tour.) So most anything made since 1973 will have good exhaust seats from the factory for warranty length. That’s why valve jobs are not are that common by themselves on modern cars.
Gas with Tetra Ethel lead (for octane boost and valve seats) was sold from station pumps much longer than that. I am surprised the EPA let’s it be sold now
at any octane rating, and am curious. Who is selling it, an aviation place, track or a speed shop?
7991LXnSHO thank you for the lesson. I know a bit about leaded gas, but not much. As far as where it comes from, I’d rather no mention that, if it’s all the same. I see you are from Kearney though. I used to live in Omaha and went to school in Iowa.
Unless your engine was built before 1975, as others have said, you're going to mess things up running leaded gas. And BTW, how meany MPG's did the cat delete cost ya?
My tri-hull is a 1970, and if I don't go to the airport and get some 110 low lead to mix with my pump gas, those valves chatter like the head is going to come off that old Iron Duke. One of these days, if I ever get money ahead enough, that old ID is going to get a more modern head, a new manifold and an throttle body carb. And then the points are going to take a trip overboard as well in favor on one of those Morosso electronic kits.
The cat delete should not have lowered the MPG unless the noise caused the driver to push the pedal down farther, quicker or more often with excitement.
@Bree if you are going away from points, check if Pertronix has a kit for your distributor. They are durable enough for industrial use, and are also available through places like Summit. They stand up to racing and daily use better than the racing branded parts in a (Chevy) forum I am in for another car.
Well, I haven't made any concrete decisions as to what points delete kit I may go with. I have a lot of other investments to work out first. Sadly, due to income restraints, the "As Sea-n On TV" has been in the garage for a few seasons. And yes, it really has been at sea on TV, if we use the term "at sea" loosely. I use to work for our local NBC affiliate, and at the beginning of boat safety week, (yes that's a thing) we would contact either the county sheriff's watercraft enforcement, or ODNR and we'd go to a local lake or river, and have them come along side and do a safety inspection on camera.
As for cats, they recirculate nu-burnt fuel particles. Granted the difference is only like 1 to 2 mpg, per cat deleted, but...........
Then why is there that T shaped tube between the two, and why doe it connect to the EGR valve?
  • Haha
Reactions: Adieu
The air pump pushes air into the convertors. The flow is one direction only. It goes into the convertors and out the tailpipe. It is for cleaner air only.
This is not the EGR system.
