99 mustang cranks no start. Help!!!
There are a few things a car needs to runs. It cranks so that's a start. There are 5 things it needs. Fuel, Air, if the filter is bad you wont be able to get air into the engine to start. Spark, get a spark tester to make sure the wires are working properly. Compression, if you have bad compression then I don't think it will be worth keeping the original engine, unless you want to pull it and make sure you don't have any cracks in the block and rebuild it, or you can just swap it and have some fun. And timing, check the timing belt and make sure it has proper tension and hasn't slipped any teeth throwing off the timing. If you want a proper guide to checking everything check out this video that goes into detail about everything I just mentioned.
View: https://www.youtube.com/watch?v=PNhuDCVIydw&ab_channel=ChrisFix
