Help with Lift Points
gaprabbit
33
So Cal
Hi all, noob here needing some help
I just bought a QuickJack system and I want to lift my 1988 4 cylinder up for the first time.
I watched Danny Johnson's Garage video that explained the lift points (
View: https://youtu.be/mKy1rNRRMRk
) but I got these metal plates that go under the front subframe and behind the floor panel on the torque box. Can someone confirm here if these are the places to put the rubber spacer blocks?
You can also use the spotwelds where the factory jack goes
Use whatever is easiest at the time
I think that would not be a good idea with a common floor jack or the flat pads on a post lift, they tend to fold over unless the deep slotted pads are used.
Once they fold over you may just as well use them as unfold them and not
Once they fold over, the structural integrity is lost and you run the risk of damage if jacking from here. Often times, jacking from this spot even with the pinch welds intact will cause the front fender to bow out slightly causing a large gap between the fender/door seam. The structural integrity of this location as a jack point depends on this pinch weld maintaining it's factory shape perpendicular to the load.
I would honestly recommend not jacking from here at all
I'm with the others. I've had those spots fold. If the factory jack isn't on flat ground it'll bend the too. One of the fist things I learned was not to use the pinch welds for anything other than the factory jack on flat ground.
We have all had them fold which mashes the fenders
My 69 has the subframe bent up a bit from hoisting over the years
Leave yours on the ground if you want
The factory lift points (the spotwelds) are there for a reason
I will still use them most of the time
My lift has rubber pads so I used to lift on the front and rear subframe with no issue. After I installed the MM full length subframe connectors, I lift on those at the front and rear with no issue, it's very solid.
If my lift didn't have rubber pads I'd use a small block of wood between the lift and the subframe connector to protect the subframe connector.
To each their own.
