Hi Guys, I'm thinking in swap my 85 GT 302 to 429, is someone did that?, is there too much modifications/trouble ?, thanks.
Thank you Noobz347, what was the major modification you had to do, if you don't mind to tell.Yep, it has been done.
Yes, there are a [lot] of modifications necessary for the swap.
Lemme see if I can dig up a [how-to].Thank you Noobz347, what was the major modification you had to do, if you don't mind to tell.
lol,.......Thank you, i appreciate all the info.Lemme see if I can dig up a [how-to].
You're going to need er...
Engine mounts
Exhaust system
Transmission
Transmission cross member
Front end Springs
Caster/Camber plates
Enough fuel system to support the whole thing
and of course, the engine combo...
It's a tight ass squeeze and your mother will blush if she hears you trying to get the exhaust system hooked up...
I'll dig around a bit. I'm sure we have a thread with pictures around here someplace![]()
Take a look at this thread before you pull the trigger:
I take it that you already have this engine on hand? If not, I would say that it [is not worth doing]. There are way better/easier/more direct ways to make that kind of power with a small block.
IMO, the only reason to full retard with big block is for something like this:
View: https://www.youtube.com/watch?v=D26SdnDb9UY&ab_channel=stangluvr
Thought you might like this one tho:
View: https://www.youtube.com/watch?v=sZYvv_BQfao&ab_channel=BlakeNichols
No, i don't have the motor yet, just looking to see what's the best option to get more power, around 500-700hp, thank you.Thank you
I thought on that too, i was thinking just on do something different, but you'd help a lot, thanks for that.For that power range and no other criteria, I would go with a 351 block. If money is no object then a DART Sportsman or Boss blocked stroker.
Why stop at 429? A 460 with aftermarket heads and intake would be the minimum I’d consider for the work.Hooker/Ford Racing/Melling 460 Swap Kit for 1979-93 Mustang - JEGS High Performance
Thinking of swapping a 460 big block in a Fox body? We just made it easier for you. The swap kit includes headers, mounts, oil pan and more!www.jegs.com
Nice, this kit help a lot, thanks 7991LXnSho for the help too.Why stop at 429? A 460 with aftermarket heads and intake would be the minimum I’d consider for the work.Hooker/Ford Racing/Melling 460 Swap Kit for 1979-93 Mustang - JEGS High Performance
Guts that will blow chunks with enough torque. I think the case end is known to flex.Wouldn't you just fab a cross plate for the transmission, a T5 has real guts.
And what transmission will work best with that?You can get 460 c i from a stroked 351w, it'll be a lot easier.
A prepared C6 or PG will do fine. I am not sure if clearance, but I know drag cars have used EM either with the big block, so the Windsor block will also work. If you want a manual, the TKX is rated to 600 ft lbs. At that point, lack of traction will likely protect the transmission.And what transmission will work best with that?
Nice, yes, i'd like to keep manual.A prepared C6 or PG will do fine. I am not sure if clearance, but I know drag cars have used EM either with the big block, so the Windsor block will also work. If you want a manual, the TKX is rated to 600 ft lbs. At that point, lack of traction will likely protect the transmission.
