I found this:
Clutch Cable Tech
MM Universal Ford OEM Clutch Cable!
We have done a lot of research on Mustang clutch cables, buying and testing almost every different cable on the market we could find. We have found after all this investigation, that the OEM Ford Clutch Cables are the best quality cables available. They have a multi-material, layered construction that provides better heat, friction and collapsibility protection than all the aftermarket cables we dissected. With that in mind, we have begun selling all year ranges of OEM Ford Mustang cables, for those customers that demand
a cable that will last. We have developed a clutch adjustment package that will work with all OEM Ford cables. Our Quadrant, firewall package will allow the use of all OEM Ford Mustang clutch cables (and adjustable clutch cables, too), however the cables all require some minor modifications.
We also sell a package with the MM Universal Ford OEM clutch cable, which comes with all the parts you need to install a Ford quality clutch cable in your Mustang with an aluminum quadrant and firewall adjuster, that requires
no additional cable modifications. This universal clutch cable will provide
more header clearance, and therefore even better heat protection, than any other cable we have found, including the 5.0 liter engine OEM Ford Mustang cables!! This cable, quadrant and firewall adjuster can be the answer to all your clutch cable problems! We have also discontinued selling adjustable clutch cables due to the poor quality and repeated returns we have experienced. Based on our research and ongoing testing, OEM Ford cables are the only solution to Mustang clutch cable problems.
The photo below compares the construction of an aftermarket Mustang clutch cable (upper cable) and an OEM Ford Mustang cable (lower cable). Note that Ford utilizes a multi layer construction which helps prevent heat from affecting the sliding action of the inner cable or causing a compression failure of the outer housing, while still allowing the cable to be sufficiently flexible. While we have looked at the construction of many aftermarket cables, none have had a construction that can compare to the quality of the OEM Ford cables.
from here:
https://www.maximummotorsports.com/tech_drivetrn_clutch_clutch_cable.aspx
It has always been the same in my memory (20+ years). What it doesn't say is where they get their cables from
Thoughts?
