Fuel pump won’t prime worked before motor was pulled
Thatslow2v
I got an 04 gt I pulled the motor to fix my header gasket and when I put it back in and hooked everything back up the fuel pump wouldn’t kick on and the fuel pump is a newer pump it worked when I pulled the car in. I check fuses which they where good I have zero voltage at the ifs switch with the key on and one pin on the pump harness has power but the other doesn’t.
