Tensioner pulley bearing
JD1964
there is enough sticking out to grab on to
3,447
1,531
194
Maryland
On a 92 5.0, is the tensioner pulley bearing replaceable or is it necessary to replace the entire pulley? I’d rather choose a higher quality bearing myself and put it in my existing pulley.
Anything's replaceable, stock pulley is stamped 2pc and riveted though, kind of chintzy, Pro 5.0 still sells a stainless one on fleebay. Upr, wazee and steeda have billet ones with serviceable bearings. I have a few of pro 5.0 ones since there here in a day or less snail mail since he's just upstate.
Upr and steeda have thiers on there sites...
I replaced the bearing in my original 83 tensioner.... You will need a press to remove the old one, at least I did... It was really tight.. Other than that it was pretty basic... I " think " there is a snap ring involved, so look for one before you beat or press on it...
I've done that, not sure on years but on mine I drilled 3 rivets and separated the 2 half's with a flathead then I put a quality bearing in it and had to source 3 small screws to put it all back together, the rivets it had original were not run of the mill rivets.
If I had to to do it again I wouldn't, on eBay there is a guy selling some really nice billet tensioner pulleys for like 45 bucks, he's sold like 400 of them, I believe they are listed under UPR, I've been meaning to pick one up.
Reactions: JD1964
They work fine... The parts store replacement junk has been a smooth plastic pulley for years and these things have been around for decades now, kind of shocked they still sell them..
It uses the same bearing that’s in the smog pump delete pulley that I just replaced. They came in a pair from Amazon for $10. SKF made in Italy. Since I already have a bearing I’m going to remove the rivets and replace the bearing. I hit the rivets in the center with a center punch then drilled 1/8" pilot and followed that with a 7/16" to take the head off and drive them out with a punch. I used machine screws with lock nuts to put it back together. Just like Praetorious stated above. All done and back on the car.
