Hey guys and gals! My name is Justin and I need help. To give a little background on myself. I have been a diesel mechanic for the last 20 years and I built Foxbodys on the side for around the same amount of time. I’ve ran into almost every problem you could think of but this one. I have a 90 mustang GT that’s been sitting in a barn for the last 24 years. The car has original 40,000 miles. I had to change the fuel pump and fuel tank, obviously changed all of the fuel lines, the fuel injectors, and the fuel rail because they were full of crud. I have replaced the whole ignition system with all original Motorcraft from spark plugs ,distributor ,distributor cap ,spark plug wires, and ignition coil. I replaced the TPS sensor because it was really out of range and did the base idle reset. I had a problem with number eight injector where the signal wire was opened. I got that fixed and got the injector working. I pulled the EEC out and replaced all three capacitors because they were messed up, it has an A9L EEC. I also went through the EEC and tested the other components just to verify everything is good. I have tested every sensor on the engine tested sensor function with everything giving the proper values. I am having the correct fuel pressure at idle and WOT. Here is the issue at idle. It runs good. It is running a little rich but running good regardless I have ran my timing from 10° to 12° to 14° with all the same outcome I decided to stay at 10 since the car is non-molested. When you start to takeoff in the car, it completely falls on its face and shuts off and will not start back until it cools off unless I hold the pedal to the floor to tell the computer that the engines flooded and then it will fire. I went back and checked my TPS sensor just to verify correct operation and I’m at .98 with a smooth transition to 5 V. I have completely unhooked every single vacuum line and smoke tested the engine with zero vacuum leaks. I checked the ignition coil and swapped it out just in case I was missing something with the same outcome so I put the new one back on. I swapped the maf sensor even though it tested good just a double check. Sorry also no CEL. I have checked all of the grounds and they all seem good. At this point, I’m absolutely stuck and passed the frustration part. Does anyone have any ideas to give me before this car turns into a carburetor car lol (jk)
