Hmmmm, I guess I'm going to have to remember FIC when it's time to order the injectors for my car.
Ive been told by my friend in Alabama that word is spelled just like it sounds... pank.I am tickled effin pink that you did all that and posted the results here.
I am going to steal your post and make it a sticky someplace. The last time I had injectors flow tested was 2000-something and [wished] I had thought to keep all the documentation.
That matched set is pretty sweet. I am 100% convinced that, that is the way to go.![]()
I would think this has more to do with piston diameter in the Master Cylinder.....Please let me know what you find out on the ponies. I have the SVE 5 lug conversion on mine...atleast the brakes are SVE. I'll need to look into it more to see which axles they used.
Just a note, my 5 lug disc conversion still has the stock booster installed and the brake pedal is really stiff. I have the 93 cobra style booster here waiting to be installed.
Are you saying basically that the EEC will be 'pushing' the lower flowing bank injectors more than the other bank with the higher flowing injectors, but both banks together would be flowing roughly equally?
Those are some nice welds!I got my new Pro M 80mm MAF mounted today. It seemed pretty huge compared to the old one. At first I wasn't sure it was going to fit.
But it tucked in behind the fender just fine. I did make a new bracket for it to hold it secure. I used the bolts that secure my MSD BTM since they were already there and i really didn't want to drill holes if I could avoid it.
I made a paper template first
Then trace it on to some steel. I had some ⅛" so I used that.
One trick I've found to get nice bends is to mark them out and cut the steel along the bend line about halfway through. Then bend it into position and weld the line where it was cut. Sort of like origami.
Then I gave it a little paint and put in some rubner grommets for where the MAF will attach to help calm any vibration
Mounted
And installed
Put my splash shield back up
Tomorrow I'll start with the injectors.
I just posted an update regarding the cobra booster.I would think this has more to do with piston diameter in the Master Cylinder.....
Are those TIG welds?
Nah, just a MIG. I'd like to try TIG someday, but I've found ways to weld just about everything with a MIG so I've put it off. Maybe someday though.
Agree. The more I deal with LMR, the less impressed I am with their product quality and fitment. Anyone else notice the same thing? Is NPD better?I am tickled effin pink that you did all that and posted the results here.
The LMR ones seem solid at 43 psi but they sure lose consistency at 90. I wonder if that much pressure is outside of their specs?To see if the 55mm MAF is causing a restriction I decided to go with a Pro M 80mm MAF. I sent them a detailed list of all the modifications and they sent out a calibrated MAF for 24lb injectors.
It's considerably larger than the old factory MAF and Vortech supplied filter. So I'm sure there will be some fabrication involved. I'll take some pics as I go and post them.
I also ordered some fuel injectors. This is where it got a little interesting. I decided to get them flow tested. I read a few posts from Noobz about getting new injectors flow tested and the more I thought about it the more it seemed like a really good idea. I felt knowing what they are actually flowing would allow me to organize them in the fuel rails so the left and right bank have even flow. That way the AFR reading I'm seeing from my wideband in the left bank should be very similar to right which is not monitored. It would also let me catch any defect.
This quote is what really got me thinking about it.
Chances are if I went lean it wouldn't be all the cylinders evenly lean and destroyed together. It just takes one lean cylinder to stop the party.
I found a local fuel injector cleaner and flow test shop. He's a racer and was really great to work with and super fast turn around time. 7 bucks per injector to flow test.
I'm using a FMU which raises the fuel pressure under boost. So I had him flow them at the standard 43.5 psi and also 90 psi so I can see how consistent they are when being pushed.
The first set of injectors I got from LMR. They are the pink 24lb injector. This pic taken after getting them back from flowtesting. (They shipped from LMR loose in a ziplock bag.)
I wasn't thrilled with the results.
The flows were pretty inconsistent with each other and one of them had a higher resistance. Had I not got them flow tested I would have never know. I definitely didn't have the warm and fuzzies about using them.
I asked the owner of the shop if he knew of a place where I could order a set of new, not re manufactured OEM quality injectors. He recommended Fuel Injector Connection. I gave them a call and I ordered a set of flow matched, new, authentic Bosch 24lb injectors. Again I took them to be flow tested.
This time the results were great. This is what I expected to see from a quality injector. They flow nearly identical.
I should be able to get this wrapped up this weekend. Then I'll do a little "tuning" with the FMU. I'm having a local machine shop make me some calibration disc sets in sizes Vortech doesn't make.
I have nothing but good things to say about LMR... their customer service has been top notch and returns never have been a hassle for me. As far as quality of parts, it depends on the supplier....ive not bought anything from them (house brand) except rims and im not exactly sure if they are responsible for manufacturingAgree. The more I deal with LMR, the less impressed I am with their product quality and fitment. Anyone else notice the same thing? Is NPD better?
Edit. Just saw how far off injector 1 is at 43 psi...still 24# but lower than the rest.
