Welp, I am no closer to solving this.
Did some more testing and verifying. Everything checks out. Nothing changed. I still have a problem. For those just tuning in, if i set my static FP to 39PSI, and then do a WOT pull in 2nd or 3rd gear, my fuel pressure drops to 29psi. This is all datalogged in my MS3 setup
So here's what I've done.
- 2 190LPH fuel pumps
- Replaced S-hose, new filter sock
- new lines from tank to hard line
- new fuel filter
- 2 different fuel pressure regulators including rebuilding my original Kirban
- new 47# injectors
- Physically removed the fuel rail and verified no blockage
- removed fuel feed line at engine and timed how much fuel came out to calculate pump volume - confirmed ~200 lph
- verify my fuel pressure reading with 3 different transducers and one mechanical gauge
- remove and block vac line. verify FP set to 39psi and confirmed even without vac it drops under load
- Rewired fuel pump circuit with 10G wire from battery direct to pump. Voltage drop checks show little to no drop
No matter what i've done...zero changes.
Not sure what else i can try here. I popped the feed line off and measured out 1 gallon of gas in 60 seconds at 12V. Doing math comes out to just above 200lph. I think what i can try next it to pop the return line off at the engine, and flow that into a 1 gallon bucket and see how much volume I get. When i took my fuel rail off, i was easily able to blow through it so I do not believe there is any blockage.
I'm scratching my head here. I do have a problem. I clearly get a stumble and lean spike thar correspond with the FP drop if i give the engine a healthy rev. I also went back through old vids and found I also had this issue when i had the A9L. I also found some way older vids of my mechanical cowl-mounted gauge and some revving and can clearly see 2 things. #1 is the engine free revs and instantly jumps to 39psi. And on key prime, the FP builds to 39psi pretty fast just on the prime. When i key prime now, the most I'm able to prime to is.....29psi.
So i'm stuck for now. That last thing is making me scratch my head. Why can't i prime past 29psi? Even if i run the pump constant via Tuner studio override, it just sits at 29psi. When i start the engine it will go to 39psi with vac off. So why engine off i can only get to 29 with the same setting. 12V vs 14V? Keep in mind, i've tried two different pumps and they do the exact same thing.
I gotta be missing something
