Upgrading to SN95 steering rack
This is all crazy talk. I just got a rack from O'Reilly's for like $150 with core exchange. It's a damn steering rack, why would you pay more.
Kurt
My 99+ GT reman rack from RockAuto was like only $108.99 with the core refund.
I guess the expensive part of the conversion was the solid hybrid steering shaft but that’s what probably made the most difference.
Yeah, no kidding. $150 for the steering rack, $390 for the Borgeson steering shaft, and $150 for the Detroit Drift firewall bearing. The rack was the cheap part.
Kurt
Reactions: gkomo
Depends on how far you are going to lower it. Offset bushings can keep you from needing a bumpsteer kit. I have both on my car but I’m an idiot and lowered it a bit.
You can see mine is also very low (in the front) with some garbage ass H&R race springs. My front tires basically tuck up inside the fenders. I plan on changing all that with coilovers but for now I don’t believe I am experiencing bumpsteer. However I’m no race car driver so maybe I just don’t know what I’m looking for.
Long story is I think you can get away without offset rack bushings but if you need them just swap them in.
Reactions: 91GTstroked
I can just about guarantee you are experiencing bumpsteer but like you said you may not really notice it. You just need to make sure the tie rods are parallel with the control arms when the car is on the ground and the suspension fully loaded. Is this the correct way to set the bumpsteer? No but for a street cat it’s good enough. Setting one up with the gauges is a huge pain and anytime you make a change you have to go through that whole process again. I’ve done it on a buddy’s American Iron car a couple times and it was not fun.
The boys in Charlotte have Father Time again for paint correction. I asked them to address the burned boot & PS fluid leak from the rack, and they just HMU with it's leaking internally. So, and I don't know if I was smart or dumb for this, but I nabbed this Ford-reman'd 99+ rack off of Ebay. ChatGPT tells me it's a V6 rack part number. In light of Jack Hidley's comments and what I've read here, seems like 99-04 are all substantially similar enough not to overthink this. I liked that it's a ford reman, but don't know if that really matters, either.
Then, I ordered the MM shaft. I noticed that Turn one allows for the option of '00 Cobra R valving. Might do that next time.
Reactions: 86HO5.0
I remember talking to Jack about that link on MM's site and he said they had some updated info and would be revising it soon. But it appears that never happened.
I can tell you when i went from my 04 cobra rack to my 04 GT rack (because the housing cracked) i couldn't tell one difference at all for everyday street driving.
About the only time you will notice the Cobra rack vs the other SN95 racks is with really wide tires up front auto crossing. This is direct info from a buddy that won in American Iron with his 88 Coupe so I just took his word for it when I did the conversions on the Coupe and T-Bird. One of the best mods on either car.
I assume I should be using the offset rack bushings? Car will be lowered.
Those things didn't exist in the 90s when we were lowering cars, and none of us died. Honestly a bump steer kit would be more adjustable and work better. Moving the steering rack North in an already crowded K-member makes the lines that much less accessible.
Kurt
Offset rack bushings serve their purpose when needed. I 100% agree that a bump steer kit is way more adjustable.
I have rack bushings on my T-Bird but it was to drop the rack to gain clearance for the oil pan. Stuffing the 351 in there with a Canton road race pan was some work. Car also has MM’s bolt through style bump steer kit.
The thing with bump steer kits is it is highly recommended to actually go ahead and measure your bump steer. The whole "Just eyeball it" thing only gets you so far and it really easy to be way off due to what reference points folks select when they try to parallel the A-arm to the tie rod.
But, actually measuring BS is a huge PITA. I've done it with the excel graph and found it really doesn't take much for it to be on-point and way off. That's why eyeballing isn't ideal but gets you close enough for gov't work.
