Got around to doing a little data logging today. I'm still feeling pretty clumsy with the software but the more I dig in the more I remember how to get around in there.
I made a few more changes over the last few days to the tune. I'm feeling pretty good about it. Pulled a few plugs and all looks well.
I'm sure most dataloggers are similar. I pulled up whatever sensor I wanted to look at and hit record. They can be added or removed when you're going over a recording. It looks like alot
If I zoom in its easier to find a particular spot.
Even though i can't see the graph the data block tracks the cursor.
I found it interesting the ACT reading comes down under boost. I figured the compressed air would raise it. It must get heat soaked when it doesn't have much air flow. It was around 170° just cruising around and pulled down in the 150°'s under boost. ECT looks good. Pulls up a touch at the end of a run but then immediately drops to normal operating temp.
I have a MAP sensor coming. It can be used a few different ways. Primary I just want it so I can data log actual boost PSI. I think my timing is a little conservative. I want to be able to cross refrence actual boost PSI with the load axis. So the MAP will add some more data to look at.
The plan is to keep things conservative and learn my way around the software. Do a bunch of research on spark tuning and when I feel i have a competent plan I'll call around and schedule a dyno session.
I bet an internet cookie that I'm closer.
