Idle problem
Also I smoked test it did not see nothing checked fuel pressure was at close to 40 psi .I disconnected the egr from the throttle body but still connected. But i but a plate on the thrutle. I have no ac .no smog pump connection. Maybe I have to replace the 02 sensor I have no cats all straight pipe. Underload it turn off sometimes.
You check for codes?
You're already throw'n parts at it, this is a common complaint and the diagnostic procedure in here:
Do what the directions say, don't jump around just because you installed new parts, they could be bad outta da box.
Best I can do cause we don't know what's been done or aftermarket parts.
Does eny one know what can the problem be this is on cold start. 1991 mustang gt 5.0 .tps is on .98v . New module new spark plug new idle control valve. Coil is good. Timing is done engine cooling temperature sensor is new .
Sounds like a bad or failing ACT and ECT sensor.....New means nothing if its faulty or not calibrated right.
Theyre easy to test using a digital voltage meter and a thermometer to read coolant temps to coinside with voltage.
The other thing that affects startup is the BAP sensor , EGR sensor and the MAF flow....
Another possibility is needing your ECU rebuilt....I use ECU Exchange.
Good Luck
  • Useful
Reactions: General karthief
