Idle problem
miser143
18
New york
Does eny one know what can the problem be this is on cold start. 1991 mustang gt 5.0 .tps is on .98v . New module new spark plug new idle control valve. Coil is good. Timing is done engine cooling temperature sensor is new .
Also I smoked test it did not see nothing checked fuel pressure was at close to 40 psi .I disconnected the egr from the throttle body but still connected. But i but a plate on the thrutle. I have no ac .no smog pump connection. Maybe I have to replace the 02 sensor I have no cats all straight pipe. Underload it turn off sometimes.
You check for codes?
You're already throw'n parts at it, this is a common complaint and the diagnostic procedure in here:
Do what the directions say, don't jump around just because you installed new parts, they could be bad outta da box.
Best I can do cause we don't know what's been done or aftermarket parts.
Sounds like a bad or failing ACT and ECT sensor.....New means nothing if its faulty or not calibrated right.
Theyre easy to test using a digital voltage meter and a thermometer to read coolant temps to coinside with voltage.
The other thing that affects startup is the BAP sensor , EGR sensor and the MAF flow....
Another possibility is needing your ECU rebuilt....I use ECU Exchange.
Good Luck
  • Useful
Reactions: General karthief
