Upper intake oxidation
MadMatt7
virginia
What should I use to remove the oxidation layer off my upper intake
Reactions: DadLife0724
My intake looked somewhat similar to that... started turning almost a green color.
I basically just scuffed it up with whatever scotch brite pad i had (maroon?), cleaned it, and sprayed it with like high temp silver brake caliper paint. Turned out great and looks like a 'refreshed' stock intake.
Reactions: General karthief
Depends if your going to recoat it or not natural finish strip it and aluminum brghtener then a neutralizing wash, might want to clear coat after words, this will give you a clean as cast look. Recoating grabs some toilet bowl cleaner scrub it with an abrasive, neutralise wash and what ever color you like. I like vht cast coat aluminum or iron if you want a darker grey, but there not a match for stock, stock also has a bunch of factory paint marks if that's the look your going for.
Speaking of paint, a few years ago I found this.
Love it. I got to where I'm painting ALMOST everything I remove with it. Alternators, power steering pumps, water pumps, thermostat housings, timing covers, and oil pans. And a few others.
Although I wouldnt use it for a intake. Prefer the "factory" look.
That looks really good. Do you remember the brand and color of paint?
No, but i can get that information in a few weeks. Will be back in the house on the 25th and can start unpacking all my stuff and organizing.
What i do know is it was a high temp aluminum colored paint i bought from O'Reilly's, but will get brand and exact color as soon as i can.
I also cleared it numerous times as well with a 1k high temp clear.
FYI it is also the same paint/clear i used to paint my calipers from my Progress Thread... maaaaaybe the paint information is buried in that thread somewhere.
