hey everyone
i own a 2001 bullit. i recently changed the iac valve on it and it ran good for a couple of weeks. now however the car idles at 900 rpms where as before it would idle at 750 rpms. i thought the iac valve had gone bad again so i took it back to the ford dealer and exchanged it. it is still idling to high. i also changed the tps sensor and still no change. any input would be apreciated. thanks everyone.
, make sure all of your hoses are air tight using maybe a butane lighter, blow by can and will create idle problems
. Try cleaning your intake manifold and your maf. I second disconnecting the battery. I refuse to oil my air-filter cause it screws with the MAF. It definitly sounds like your air intake at some point is dirty.
