01 Bullitt door panel removal...help!
there is a small plastic pin to remove inside the door hinge area down on towards the bottom of the panel, the door switch bezel pops up, philips screw driver on the switch harness will remove the switch bezel, and the main panel will slide up enough to clear the door lock pin, then kinda out toward yourself to clear the door handle.
