maf cleaner worked for me. i had lean codes in bank 1. the off road x needs either mil eliminators to take care of those 2 rear o2 sensors or ive heard you can just pull the fuse or jump it. a pair of mil eliminators run 50 to 60 for the pair. because of the oil k and n uses that maf will be more clogged than you can imagine. you should do one thing at a time. it seems with your situation, its not going to go away over night.i'm thinking about picking up an IAC from autozone along with some MAF cleaner.. i dont expect this to fix my problem; however, before i had this problem, i did have a problem with the ilde. IAC is only $50, so it wont hurt to go ahead and get it out of the way. Thoughts?
