'01 GT cracked intake manifold
grendal
27
Houston, TX
I know this is a common problem and it exists on an '01 GT that I may be buying later this week. At one time the Bullitt intake was a big deal as a replacement part for these. Is that still viable? I certainly wouldn't want to replace it with another crappy plastic piece.
Any other worries to look at on a 2001 GT?
Replace it with an 02-04 PI intake with the aluminum crossover for a minimal cost. Bullitt intake swaps are still pretty pricey and labor intensive.
It is worth it on a modified, drag car or an FI car. Otherwise, the stock replacement with the aluminum crossover is fine. The stock PI intake is not that restrictive.
I did a quick search for you on the database for wrecked cars with parts being available. The only one I found is out of Fresno, Cali.
It is from International Auto Wrecking. The number is 559-485-3555, and listed for 125. Not sure what it includes, since you need the lower and upper. It might include both, which would be a steal. However, you would still need additional parts/gaskets to make it work. Give them a call, and price it out.
Remember, that you might add some heat with this intake, but you are also adding weight to the front end of the car. It's worth .1-.2 on a bolt on car, so make sure you weigh the gains of going with it for your setup if you go that route:flag:
