02 Readings Again
dcurtis
688
I let my car cool off completely so I could retest the voltage at the comp to the 02's and I got
Left_____Right
.6v______.2v
.68______.3
.7 _______.37
.71______.4
.71______.42
.72______.44
.73______.46
.73______.47
.76______.52
.75______.51
It basically stays at about .65v left and .3 at idle, the .76___.52 is when I gave it some gas for a second and then it went back down to about .65 and .3, what do the voltages mean?
The voltage slowly raised to the .6___.2v which is where I started keeping track of it, it took about 2 or 3 minutes to get there. When I let it sit after gassing it it slowly went back down to the original readings of about .65 and .3
The right 02 will only register in milli volts for the first minute to 2 minutes or so also
Thanks for your help
Your meter might be averaging the readings or have a low internal impedance or something weird like that.
The readings should obviously toggle between 0.1 and 0.9 volts atleast once a second. They don't read a static voltage - if they do either your DMM is causing the issue or both O2's have issues.
You might want to check the HEGO ground since you're not waiting a super long time before testing. With properly functioning HEGOs, they light off within a minute in my experience, and can take as long as two minutes.
Good luck.
What exactly do you mean when you say, The readings should obviously toggle between 0.1 and 0.9 volts atleast once a second? and, With properly functioning HEGOs, they light off within a minute in my experience, and can take as long as two minutes. And last, how and where do I check the HEGO ground?
The right 02 was replaced Wednesday, and I don't know how old the left is but I will pick up that next week so they will both be new.
When your meter is on the O2 signal wire, your reading will vary (or it should). Here's an example of how mine might read:
0.20, 0.92, 0.14, 0.85, 0.23, 0.72. That would all be seen on my meter in about a 5 second period.
The way the puter works is to correct and overcorrect constantly. It would be like teaching a kid to bowl. You put two 2 x 4's on the bowling lane, one foot from the center of the lane. No matter how the kid throws the ball down the lane, it will bounce off the 2 x 4's and end up in the middle of the lane by the time it reaches the pins. Same kinda deal with the narrowband O2s.
O2's dont start providing useful info until they reach about 600*F. When you start the engine, it takes them 30-120 seconds to reach this temp (light off) and become useful. If you start your cold car and immedately take a reading, it can suffer from great hysteresis (it will be nearly a constant value). The heating circuit on the O2 is what makes it light off so quick (older O2s, called EGOs, were not heated and could take over 5 minutes to light off). If your heater circuit is not working and you're doing your testing relatively quickly after starting the car, that could be an issue.
Good luck.
