03 4.6 In A 2000 Gt, Clutch ?
4cammer72
Likes to drop it and leave it crusty lookin
Mar 28, 2007
90
west columbia south carolina
just wanted some confirmation on this,
getting ready to drop the motor and tranny back into the stang and when starting to install clutch see it does not work.... so im guessing 03 stangs all use a 11 inch clutch not the 10.5 like the 2000 does....
Yes, the transmissions were different between the two years. 2000 used the T-45 (if memory serves correctly...I could be wrong) and the 2003 used the 3650. The switch came in mid-2001.
Just make sure the clutch matches the flywheel and you will be fine. As in, if you have a 11" clutch, get an 11" flywheel. Same trans input spline count, so no issue there.
