I've been guiding my Dad some when it comes to mods for his '03 Convertible. So far he's done:
Bassani Cat-Back
Steeda Air Filter w/ heat shield (can't really call it a CAI)
Steeda Tri-Ax shifter.
I was impressed with the gains when it put down 422 rwhp on MC Racing's Dyno here in Merriam, KS.
My question is obvious - what would you recommend next?
He just had the warranty extended to 75K, so we have to keep that in mind. I was talking with him about the Apten Performance ported Eaton OEM blower, a pulley change, and doing a Bassani X-Pipe w/ Cats. Maybe some Steeda IRS bushings - whatever will help get rid of the wheel hop. Can anything be done with the ECU flash without warranty problems?
Bassani Cat-Back
Porting the blower or swapping a smaller pulley will void your warranty if you have to have warranty work done on the motor itself and they find that you messed with the S/C. The mid-pipe is a good next mod, as is the DiabloSport Predator handheld tuner. Be careful, as it is still up in the air as far as whether the tuner can be detected or not. Rumor has been going around that all the dealer can do is tell the last time the CPU was reset, such as when you disconnect the battery or something like that. If you do have a custom tune they say to re-install the factory flash and then have around 10 driving cycles before you bring the car in for service. Not much more power to be had other than them unless you start messing with the blower or pulley.
That's what a lot of us are contemplateing right now, including myself.
