You best bet is to replace it with a straight axle. You can install the stiffer dampened shocks, the stiffer bushings, the MJ Chip/Billetflow differential cover brace, and stickier tires. All those together will help to eliminate the wheel hop, but in the end if you really want to stop the hop and cut some good 60' times the only real choice is a straight axle...
U.M.
