I have a 03 GT, and well my check light was on... It is that time of year to get my Tags renewed, so I went to Autozone and had them run a scan. It said bank 2 sensor 1 was slow response. So I replaced it and I replaced the other side as well. Well after going through the "drive cycle", the light came on again. I took it to Delk and they looked at it and plugged in their Predator Tuner to read the codes. Well the Predator read that there was NO codes, that everything was fine...Even thought the check engine light was ON!! I am still confused at this. So Delk cleared the codes for me, and I was on my way to go through the drive cycle yet again...
Well after awhile wouldnt you know, the check engine light came on again. And again it said bank 2 sensor 1 slow response. Has anyone else had this problem? I have longtube headers and hi-flow cats and Delk put in o2 wire extensions in. Is the extensions giving me the slow response?
I almost bought a tuner, but I was told by Delk that I could use it and disable the sensors, but I would still fail emissions because they would be able to tell that I turned them off and the car would fail..
