'03 Vert Headlight and Rear Seat
loopflow
A couple of moths worked their way inside the front head light lense and are visible at the bottom of the light when standing in front of the car. How do you remove the light? I noticed the twist in bulb socket and two clips at the top. Is there anything else?
Also, I need to remove the rear seat and what is the proceedure for this.
Thanks for any advice you may have.
That's all there should be to the head light...just pull up on the clips and maybe squeeze some tabs in the back that hold it in and it should just pop out...
as for the rear seat, run a thin flat headed screwdriver under the front edge of the bottom section of the seat and you'll find 2 clips that you'll have to push in on and the bottom seat pads will come out...and I'm not sure how to get the back of the seats out on a vert, on a coupe they fold down and there's about 5-6 bolts holding it and the head rests in that need to be taken out...
