I just put a 04 4.6 in my 96 GT and everything went okay. Except the 04 exhaust manifolds will not fit the 96-98 UPR X pipe that I have, so now i have this stupid ass exhaust leak. I am just going to buy LT's my question is what is a good brand to get that does not cost a fortune? Also i have to get a new midpipe to accept the LT's. I was going to get a Prochamber but somebody told me they are really quiet, and that i should get the O/R H.
When we did the swap I used my 96 wiring harness which had two ECT sensors the 04 motor only has one spot for a ECT sensor. So i have been runing around with one unplugged the PCM thinks the motor is overheating and runs the cooling fan at all times. Is there anything else I can do other than drill and tap other sensor?
Also I used my 96 flywheel and clutch because my 96 clutch would not bolt to the 04 flywheel on the motor. Is the flywheel that came on the 04 motor an 11 inch? Is the 04 flywheel and clutch the same as the cobra's? If it is the same I am just going to use that flywheel and get a new clutch.
Thanks
Thanks
