06 GT firewall amp wire
jahnplay
im trying to wire the power my amp from the battery to my amp which is in the truck so is there a whole in the firewall that i can put the wire through or i got to use the one behinde the wheel?? thanks
and can you tell me where it is
There is a large grommet through the firewall on each side of the car. To access it you need to take off the front wheel and remove the rear half of the fender inner liner. To remove the liner, there are about 6 reuseable push-type body pins. Use a small flat screw driver to pry out the center lock of each pin then pull pin out. To reach an amp in the trunk you could go through the passenger side firewall, under the door sill plate, under the rear seat, and into the trunk.
