  • 2005 - 2009 Specific Tech
06 Gt Misfiring On Cylinder 4
  • Thread starter Thread starter Midnight 06
  • Start date Start date Oct 14, 2017
  • Tags Tags
    06 gt help
M
Midnight 06
  • Oct 14, 2017
I have a 06 gt and I replaced the plugs to motorcraft platinum. No problems until I got on it at it started to misfire on cylinder 4.
I hooked a noide light to the injector wires and cylinder 4 had a weaker pulse than the others.
And I checked the plugs just to make sure there was no cracks. And it is throwing code: p0354 but I'm sure the coil is fine.
I don't know how to go about fixing this.
Car isn't stock and any input is helpful at this point.
RaggedGT
Mod Dude
Jul 20, 2014
4,739
3,188
203
Taylorsville ky
Oct 17, 2017
  • Oct 17, 2017
Have you tried swapping the number 4 coil for another cylinder and see if the misfire follows?
rd
3,316
63
109
Ocean Springs MS
Oct 23, 2017
  • Oct 23, 2017
Pull the codes, it should give you some indication of the problem. Next step is swap coils or similar, as noted.
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
R
Misfire at high rpm! Help
  • Ryanm2018gt
  • Jan 2, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Jan 17, 2026
highplace11
H
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 10, 2026
gkomo
New misfire after replacing valve seals/springs.
  • SpeedofDarkness
  • Aug 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 24, 2025
SpeedofDarkness
