*Forgot to add*
I dynamated the area under the center console and rear seats. It made a world of difference with the little noises that come through and the heat as well.
Also, ghedeup123, I was thinking about your problem more.. and thinking about my desire for a Hurst Shifter. In reading up on how to do the install of the Hurst, I had a thought. Could it be that the dust seal was not properly re-installed? I know some folks install the Hurst and notice no change in the tranny noise, while others notice a big change. I personally drove a V6 with a Hurst and the tranny noise was very loud. Might the loud Hursts just have improper reinstallation of the dust seal? It seems like that would block a good deal of the noise when installed properly.
S197 Ford Mustang HURST Short Throw Shifter Install - Ford Mustang | StangNet.com
Just a thought.
Dear 69mach1-409, I am confused by your posts, they seem to be contradictory. Is your transmission still noisy as hell after the dynamat? I am concerned because I am very close to installing a Hurst Shifter, and I was planning on dynamatting the whole cab so that after the install, it was actually quieter than before. It sounds like you liked the dynamat? But maybe you are still looking to make things more quiet?
My concern with the noise is that it takes away from the sound of the engine. I could get louder exhaust, or... try and reduce the tranny noise.
That sucks to hear about the trans noise. My 07 GT trans is quiet as can be. Have you tried changing the fluid? I put Royal Purple Synchromax in mine and it shifts much better.
I think you may be right, as the dealer told me today that what I was hearing was totally normal. If so, the Ford Motor Company is indeed in trouble. My GT premium cost around $30k, granted that is with options. I have driven other cars in the same price range that did not exhibit this kind of behavior. I agree it's a V8 on wheels but surely they make a trans that doesn't sound like it's about to break.
It's a shame, because otherwise I love the car and this noise completely ruins my driving experience. The dealer pointed to the Hurst shifter, didn't know what it was but knew it was aftermarket. The noise was there before it was fitted but now is more apparent.
I'll take your advice and see what some Dynamat can do for me.
Colin
Ford is nowhere near "in trouble". The S197 is leaps and bounds ahead of the previous generation Mustangs in terms of quality control and overall ride comfort and noise reduction.
You're going to hear noises with any aftermarket shifter however, the MGW is probably the best bet all around.
The dynamat suggestion is excellent and works great. I'm buying some myself.
Just a thought for the original poster. I too thought my new 08's tranny was a little noisy and hard to shift when cold. At about 3500 miles I switched it over to Mobil 1's new multi vehicle synthetic fluid. It meets the Mercon V spec and made a big difference in shift quality. It also seems to have a little less general gear noise than before. Might be worth a try. It holds 3.2 quarts.![]()
I second that!If the 3650 takes a dump, I am going to upgrade to a 6060.
