1 3/4" vs. 1 5/8" long tubes
  • Thread starter Thread starter Rockin GT
  • Start date Start date Aug 2, 2008
R
Rockin GT
  • Aug 2, 2008
Which size is better for my application? My exhaust valves are 1.550" I may add a supercharger in a couple years. Currently running 300 rwhp. I'd appreciate any guiddance or links to relevant test data. Thank you.
EMW150
2,020
Roaring Spring,PA
Aug 3, 2008
  • Aug 3, 2008
Definately go for the 13/4".
R
Rockin GT
  • Aug 3, 2008
Thank you. Will the 1 3/4's fit w/ the 7 qt pan ok?
EMW150
2,020
Roaring Spring,PA
Aug 3, 2008
  • Aug 3, 2008
Which brand headers are you looking at? The BBKs fit pretty good. You shouldn't have any trouble with pan clearance unless the DSS pan is different than most. A lakewood scattershield would need some grinding near the starter, but other than that they fit pretty good.
R
Rockin GT
  • Aug 3, 2008
I should be ok then. I'm planning on getting the ceramic coated BBKs. The DSS pan is a modified stock pan w/ a wider bottom portion of the reservoir. The MAC LTs I have now don't have a lot of clearance to the pan and required some reshaping near the starter. My main complaints w/ the MACs though is frying my clutch cable and loud resonance from the pro chamber x-pipe when cruising.
N8Miller
I need NOS....make it 2 of the big ones
2,661
Kingston, PA, USA
Aug 3, 2008
  • Aug 3, 2008
ok, i can tell you this.....
when you get them, get a 1 3/4 and a 3" collector. the collector is where most of the restiction is like on the BBKs (which fit really well!) and the MACs and Hookers have 3" collector that flows alot more!
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Aug 4, 2008
  • Aug 4, 2008
BBK's have a 3" collector. They are about 7" long. The aforementioned ones are around 10" long.
N8Miller
2,661
Kingston, PA, USA
Aug 4, 2008
  • Aug 4, 2008
wrong, they are 2.5" ball/socket!
EMW150
2,020
Roaring Spring,PA
Aug 4, 2008
  • Aug 4, 2008
They are a little over 21/2" but with his heads they'll work fine.
N8Miller
2,661
Kingston, PA, USA
Aug 4, 2008
#10
  • Aug 4, 2008
  • #10
they will work for now, and with his heads, but hes gonna need all the scavenging he can get when he does that blower!
EMW150
2,020
Roaring Spring,PA
Aug 4, 2008
#11
  • Aug 4, 2008
  • #11
You're right. I forgot about the future blower.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Aug 5, 2008
#12
  • Aug 5, 2008
  • #12
Wrong, they are 3.00".
The ball and socket joing area goes down to 2.37" for seal, but the collector is 3.00".
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
  • dan50
  • Jul 18, 2026
dan50
Engine 2003 Mach 1 Automatic Upgrades assistance
  • SJK1417M1AT
  • Sep 25, 2025
SN95 4.6L Mustang Tech Dec 21, 2025
01SVTvertt
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
