1/4 mile HELP!!
  • Thread starter Thread starter khaotic89GT
  • Start date Start date Feb 23, 2004
K
khaotic89GT
84
Sunny California
Feb 23, 2004
  • Feb 23, 2004
I have seen mustangs run high 13's at 101MPH or really close to that. Then why is it that my car runs 14.5 at 101 MPH At california speedway. I'm running soso goodyear slicks and holding my start rpm at about 3000 grand (otherwise the tires spin) I already got new MT drags to take care of that but, still why is my car so fast (MPH) yet so slow (1/4 times)? Please help me out if you can. THANKS STEVEN
P.S. I have yet to run the MT's cuz it been raining. Weather sucks sometimes.
87TurboMKIII
29
  • Feb 23, 2004
What are your 60' times? That might be the reason, or at least one of the factors you are getting slow times. The weather might also have something to do with it.
R
redterror302
895
Mertztown, PA or State College, PA
Feb 23, 2004
  • Feb 23, 2004
If you are running the same mph as cars that are going high 13's but you can only muster off a 14.5, then that means you are lacking in traction. Like previously stated, what were your 60' times for this run? The mph shows that you should be 13's if you had traction.
sixty9boss302
234
Pittsburgh PA or Rochester NY
Feb 23, 2004
  • Feb 23, 2004
I think you just need to get your 60' times down. I have heard a lot of talk about guys with slicks leaving the line at like 4500 or 5000rpm and still keeping traction. Im sure with some new slicks and nice burnout to warm em up your 60' times will drop and you will get greast traction all the way through first and 2nd. good luck with that.
Greenracing
109
Puerto Rico
Feb 23, 2004
  • Feb 23, 2004
please post your 60' times and also how much psi do you inflate the slicks.
what_stanger?
I am the mailman!!
1,697
Northern Illinois
Feb 23, 2004
  • Feb 23, 2004
hahaha, we could have used this question a while back (When i tried explain somthing to ford muscle 86)
anywho, these people are for the most part correct.
although it could be the driver as well, you have to think about time, everything ttakes time, and i know you know this, but REALLY think about it once. all the time gather in shifting as fast as humanly possible (and or powershifting with that) added up can reduce times alot.
if you're granny shifting or not really doing all you can, it can help
but mostly it probably IS the 60' time.
as a general rule, for every tenth of a second decrease in the 60', it will end up being worth 1.5-2.0 second decrease in the ET!!!!
now this isn't going to prove correct if you change a shift point in one good 60' run, and nail it on the money in a bad 60' run.
work on the 60's, get some drag radials, or get some slicks
and a FYI, my car has went 13.39@99mph, and i've got vids of 13.5x@99/100 if interested.
axeman and millhouse, 1bad89, and a few others all have good ETs with relativley low trap speeds....it happens all the time
what_stanger?
I am the mailman!!
1,697
Northern Illinois
Feb 23, 2004
  • Feb 23, 2004
i've left the line on BFG drag radials (slicked) on spray, at 5000 rpm, and hooked it....so yeah, guys on slicks do that all the time
if anyone is leaving the line at 2k or 3k rpm and they've got slicks, they've got problems!
millhouse
1,985
Simpsonville, SC
Feb 23, 2004
  • Feb 23, 2004
K
khaotic89GT
84
Sunny California
Feb 23, 2004
  • Feb 23, 2004
High Starts
I'll try going higher next time I go to the track. what psi should I be running in my slicks? they are tubed MT's. I not sure about the 60's can't find slips. But I know they are like high 1.'s
One more thing my rear is stock wont going higher brake something??????
what_stanger?
I am the mailman!!
1,697
Northern Illinois
Feb 23, 2004
#10
  • Feb 23, 2004
  • #10
well as far as somthing breaking in the rear (axle, ring/pinion, spiders, EVERYTHING) i can't say if it will break or not...
but mine is stock with the exception of a rebuilt limited slip and 3.73 gears, and its held up so far, i've cut lots of 1.7x and 1.8x (and 9s) 60' times, at least 30, so i would THINK you'd be okay, but everyone is different.
as far as pressure in those tires, i'm not sure..., i ran 12 psi in my bfgs last time out and got my best start ever, 1.70 on the money.
i thought slicks could go even lower.....
if you're running 14.5@101 or somthing, you've got somthing more than 60' going on there (unless you're above 2.0 range and you're not sure?)
1.9 is respectable, but with the power of 100+ traps AND the slicks, i would think 1.8 would be more common, and probably 1.7s depending on your ring and pinion, i didn't even check the ratio, sorry i'm always in a hurry
p.s., Millhouuuuuuuse!
millhouse
1,985
Simpsonville, SC
Feb 23, 2004
#11
  • Feb 23, 2004
  • #11
If you truly do have the stock rear gears, that is your problem (atleast a portion). Without some 3.55's or higher, you going to bog horribly off the line...and then play catch-up the rest of the run...and no, new gears will not hurt a thing if installed properly.
millhouse
1,985
Simpsonville, SC
Feb 23, 2004
#12
  • Feb 23, 2004
  • #12
Hehe, I'm at work...researching some designs for aftermarket hummer wheels
K
khaotic89GT
84
Sunny California
Feb 23, 2004
#13
  • Feb 23, 2004
  • #13
sorry
I ment launching higher not a higher gear
axeman
1,348
Elizabethtown, PA
Feb 23, 2004
#14
  • Feb 23, 2004
  • #14
everything in racing is a risk. chances are good you'll end up breaking something in the stock rear. on the other hand, alot of people do fine (for a while anyway). i'd say you definatly have to improve on your 60'. one of the most important things is traction.
895.0COUPE
86
LONG ISLAND, NY
Mar 13, 2004
#15
  • Mar 13, 2004
  • #15
Yea I agree with everyone else. THe E.T. shows the traction and the Traps shows Horsepower. I have an almost stock stang with the stock 3.08's in the rear and when I tried slipping out at 3k on drag radials I bogged horribly and the car didnt seem to move until it hit 2500 or so. That resulted in a best of 14.8 that day when I have run 14.5 on street tires, so the launch is very important. I should do better this year. I wouldnt even think about running slicks unless I had 3.73's or 4.10's. I dont see gears in your sig so I would suggest those, as they are going to be my next mod as well.
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
New daily driver help needed.....not a mustang but mustang drivetrain.
  • Wayne Waldrep
  • Jun 17, 2024
  • Other Auto Tech
  • 3 4 5
6K
Other Auto Tech Jul 28, 2024
manicmechanic007
J
Please help!!!
  • JiggaHawkin
  • Sep 26, 2020
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2020
JiggaHawkin
J
9
1/8th Mile Time?
  • 93lx308
  • Jan 12, 2018
8K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 23, 2018
RangerJoe
