Lol.... Come on y'all. I want the circuit completed so everything else thinks the compressor is turning. I've tried unplugging the compressor and obviously the switch inside the car does nothing then. I want to put something that won't burn the car down between the two wires on that compressor connector.So, remove the connector from the A/C clutch assy.![]()
This discussion has honestly helped me find a couple discussion elsewhere that I would never have found without y'all so thanks. Stick with me on this and we'll get it i think.
What value should it be?Measure the resistance of your clutch coil.
I know I wouldnt be seeing the load by the compressor, but if i could bypass it by jumping the plug and it still did the jolting, I'd know for a fact it isn't inside the compressor.The problem with your assumptions in this scenario is that even if you [complete] a circuit, the A/C still isn't simulating normal function. You have one or maybe even two pressure switches and without a wiring diagram, Lord only knows what else.
What leads me to believe otherwise is that it has zero reaction with the compressor unplugged and not jumped.Everything else should think the compressor circuit is completed. What leads you to believe otherwise? The difference between positive and negative across the clutch coil induces the E-M field, but that field doesn't energize anything else or send a signal back. You can see that here:
That, of course, is for a fox, but hey... that's what we know, here.
See my above reply on bypassing compressor.You can simulate electrically the A/C being "on" all you want, but it will never simulate the load on the system, either from the power required to spin the compressor or the flow of refrigerant through the system.
If possible, I would hook up a set of gauges to the A/C system and tape it to the windshield and drive the car. The pressures may be normal at idle, but when driving down the road you may have higher than normal pressures building up in the system creating extra load.
The Grand Marquis also probably has ambient air temp sensors in the duct-work and in front of the car to measure outside air temp.
Did you mention if this vehicle has Auto A/C or Manual A/C? The electrical system is different for each system.
Yeah but that just makes the compressor run no matter what. I want the actual compressor not running but the rest of the car to think it is to eliminate the compressor. My friend mentioned something about a diode. I'm hoping someone can at least tell me what to look up to do that.
