10 psi compression
Sweetmarie66
67
Hey folks! Been awhile since I was here, so the inline 200 in our 66 had a dead cylinder, was really odd, ran great the day before, did a dry and wet compression test here are the numbers in the attached photo with the plugs as well, why the H would it run great the day before then next day it had a dead cylinder, #3 ? Blown head gasket? I'm thinking this is a way bigger problem. rings for sure with numbers like that.
I once had a 289 stick an exhaust valve open by close to a quarter inch while I was driving. Tore it apart on the roadside and saw one valve lower than the others. With few other options, rapped on it with wood and a hammer until it closed, put the covers back on, and made it home. It's a wonder the pushrod and lifter didn't get spit out.
The heads were redone shortly after...
Reactions: Sweetmarie66
