10w30 oil
  • Thread starter Thread starter bad98rt
  • Start date Start date May 23, 2007
bad98rt
Indiana
May 23, 2007
  • May 23, 2007
I am about due for an oil change. I usually use the standard 10w30 valvoline, but I was just wondering what kind of oil you guys use in your 5.0 ponies. Thanks
R
RioRed4v
24
Las Vegas
May 23, 2007
  • May 23, 2007
10w30 here also
Turkey Sammich
I can't fap normal. I cracked a rib, then my ankle
Jul 12, 2006
154
May 23, 2007
  • May 23, 2007
The same here. I use the 10w30 valvoline high milage.
cenok is family
1,409
69
79
Norman, Ok
May 23, 2007
  • May 23, 2007
i used to use 10w40 valvoline until i tore my motor apart a few weeks ago and found sludge buildup. i will no longer be using valvoline. i hear mobil is really good. i'm switching to synthetic after i get my motor back together.
R
RioRed4v
24
Las Vegas
May 23, 2007
  • May 23, 2007
the only downfall i've found with switching to a syn oil on a higher mileage motor is that it can sometimes create leaks in gaskets. i know it did on my old fox and some of my buddies as well.
sounds like yours is a new engine, but i'm just tossing it out there as a caution to others.
i recently just switched to the high mileage castrol stuff.
cenok is family
1,409
69
79
Norman, Ok
May 23, 2007
  • May 23, 2007
yeah i've heard that too, that's why i've never used it before. I'm about 90% done with doing a complete engine rebuild with a few upgrades, being the only reason why i'm considering synthetic. Everyone is saying to do it, so i probably will.
ACSPONY
20+ Year Stangneter
Oct 10, 2004
711
Ohio
May 23, 2007
  • May 23, 2007
Not sure what the previous owner ran in the car but it just turned 85k the other day. I run 5W30 Mobil 1 Synthetic and haven't had any leaks.
MrStang123
65
NY
May 23, 2007
  • May 23, 2007
Then maybe switching to synthetic blend before the full fledged synthetic would be best if thats the case?
89five.o
26
  • May 23, 2007
I used I believe the 10w-40 from royal purple for quite a while but after the prices got outrageous I went to mobil 1 synthetic 10w-30. If it's good enough for exotics then its good enough for my ride.
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
May 23, 2007
#10
  • May 23, 2007
  • #10
Whenever I first get a car, I start off with 10w30 and see how fast it eats/leaks oil. If it starts munching that, I bump it up to 10w40. The Notch consumes oil at a rate of 1 quart every 800 miles or so, and moving it up to 20w50 didn't do anything to slow the rate of consumption, but it does help keep the oil pressure up a bit more during the hotter months. Thus, I run 20w50 in the hottest months (May through September) and 10w40 the rest of the time.
The TurdBird recommends 5w30 from the factory, but at 122k+ miles, the motor isn't quite as tight as it once was. Thus, it gets 10w30.
Both cars get Castrol GTX High Mileage - just decent middle-of-the-road stuff. I'm kind of tempted to go with Mobil 1 synthetic in the TurdBird with my next change, mostly because I do almost all highway miles and (so far) it doesn't burn or leak any oil at all, so it'd be nice to stretch it out about 5,000 miles or so between oil changes instead of every 3,000 miles. (Mobil 1 has that so-called 15k-mile oil, but c'mon ... nobody makes an oil FILTER that'll hold THAT much crap yet for a 4.6L, do they? )
BigHairyMonkey
411
Houston (Bellaire) TX
May 24, 2007
#11
  • May 24, 2007
  • #11
i use 5w30 Mobil Clean 5000
onefstsnake
792
Northern VA
May 24, 2007
#12
  • May 24, 2007
  • #12
GTX 20w50 in the summer and 10w30 in the winter.
90_Red_LX
668
Asheboro, NC
May 24, 2007
#13
  • May 24, 2007
  • #13
I run valvoline 10w30. All thats ever been put in the motor. Once I rebuild it though, I'm switching to german castrol. From what I heard mobil isn't a full synthetic anymore.
monte87
876
18
49
new york
May 24, 2007
#14
  • May 24, 2007
  • #14
i use 5W30 Quaker Q full sythetic, Castrol Syntec or Royal puprple, actaully all three. in the summer an all Sytheitc as well-Just up the weight to 10W30.
Later Ant
monte87
876
18
49
new york
May 24, 2007
#15
  • May 24, 2007
  • #15
FYI- No leaks whatsoever 105,000 miles, Just whenn i use the 5W30 its eats oil a bit, but nothing sick, When i up it to 10W30 0r 40-a whole lot less. nature of the best though.
Ant
85_SS_302_Coupe
6,945
1,598
223
Northern KY
May 24, 2007
#16
  • May 24, 2007
  • #16
I use Dollar General oil, $.99 a quart, whatever weight i can get since it's eventually going to leak/burn out anyways
When i get it changed it depends on what time of year it is. Typically though i use 10W40 Valvoline Max Life with a bottle of Lucas Oil added in.
fox-gt
204
TN
May 24, 2007
#17
  • May 24, 2007
  • #17
10w30 Motorcraft oil and filter.
91ghp5.0
42
Somewhere
May 24, 2007
#18
  • May 24, 2007
  • #18
10w30 here. Usually Valvoline All-Season or Castrol.
Ninja edit: Full dinosaur stuff here, no synthetic.
Oil choice for after break in period.
  • Sask84gt
  • Feb 28, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 14, 2026
Praetorious
P
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
J
Intake
  • James S
  • Jul 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
James S
J
