12v Key On???
there are several places you can tap 12v with key on from the drivers side-if you've got a haynes or chilton manual with a wiring diagram, and a multimeter (they're worth their weight in gold IMO) you can find one with no sweat.
red w/ green stripe is a good one for 12v ign hot though...it should be in the dark red connector that ties your chassis harness to the injection harness...it normally resides right around the brake booster or master cyl on the FI cars
like i mentioned in the last reply...red w/green stripe is a good one under the hood, or poopdawg said, positive side of the coil works too...the FI stangs have TONS of places to tap 12v, just grab a multimeter and start probing
