13 gallons of paint thinner in my gas tank.. peoples reactons?? LOL
Someone told me when I first started with cars as a kid that if I sprayed a little water in the intake while the car was running I could steam clean the engine from the inside.
When something seems wrong it usually is.
(oh never did it, because even as a noob it seemed f**ked up)
This dosent steam clean the engine. It will remove carbon build up on valves etc. It is an old school trick that works. You just dribble it into the carb a little at a time on carbed cars.
I know for one thing right off the bat you need to run higher fuel pressure. If you get that from an adjustable regulator or bigger injectors i don't think it matters - but i think on a bone stock car you'll damage it.
I read up on 04sleeper's terminator when he swapped to e85. There was alot to change on the fuel side so he could safely run it with every tank.
no to run straight e-85 you need 33% more fuel, i compensate mine with a little richer tune, the inside of my fuel rail is spotless, and nothing has "ate" through, been doing this for about a year, but only maybe 4 gallons with a full tank.
