traction control i.e advance trac can be disabled by holding the brake pedal and traction control switch for a few seconds it will say it on the cluster
theres plenty different cold air intakes out there pmas jlt etc.. take your pick. For what its worth ive made the most power with the pmas one.
plenty sc's out there as well. Edelbrock, procharger, vortech, paxton, whipple, etc...
Im a procharger dealer and the majority of what we do in house sc wise is procharged coyotes so im a bit partial to them
tire size is up to. Most run drag radials when you go boosted.
Theres a bunch of programmers out there. I personally use my own proprietary software for them but there are plenty commercial ones. The most economical is the Syked programmer but there is a waiting list. SCT has been around since day 1 and many use it as well.
Typically stock is around 335hp. Tuned about 360. CAI +10. Throttle body and cobra jet intake +25. Long tubes +15.
Keep the stock gears and get a high stall converter. When /if you go boosted youll want to toss in billet oil pump gears as well.
