  • SN95 4.6L Mustang Tech
150 shot?
  • Thread starter Thread starter CENTENNIALSTANG
  • Start date Start date Nov 4, 2005
C
CENTENNIALSTANG
Houston
Nov 4, 2005
  • Nov 4, 2005
I am running 125 shot of NOS now. I was wondering if you guys think it would be safe if I dropped a better fuel pump in and ran the car on a wideband and tuned it for 150 shot. Would it blow up my motor or not if everything is done correct. Right now its tuned for 125 shot and I have NGK TR6 plugs.
G
Gunmetal5oh
936
USA
Nov 4, 2005
  • Nov 4, 2005
If you do .. make sure you retard the timing 5 degrees. Running high octane fuel would be smart.
J
Justin03GT
199
Mount Pleasant, SC
Nov 4, 2005
  • Nov 4, 2005
if you set it up properly sure it can be done...but you arent gonna see a lot of extra power from it because you have to cut so much timing and add so much fuel...a friend of mine did it and only made 6rwhp more than the 125shot because of that reason...
SamMan
121
Denton, TX
Nov 4, 2005
  • Nov 4, 2005
Yeah I was thinking that same thing. Once you retard timing an all you may get close to breaking even. That being the case I decided to just get mine tuned better.
G
Gunmetal5oh
936
USA
Nov 4, 2005
  • Nov 4, 2005
If you're going for the most power rather than efficiency a larger shot might give you that edge. Of course you'll use more nitrous.
2kyellowgt
224
Nanuet, NY
Nov 4, 2005
  • Nov 4, 2005
I run a 150 shot. It's perfectly safe with a good tune, I also added a focus pump and #30 injectors. I didnt change my timing from the 100 shot but I added the above items. My A/F is dead on and Picked up 38 Hp and 47 tq from 100 shot.
If you run the 150 shot you will definetly have the edge.
SamMan
121
Denton, TX
Nov 4, 2005
  • Nov 4, 2005
What plugs are you running?
2kyellowgt
224
Nanuet, NY
Nov 4, 2005
  • Nov 4, 2005
Im running NGk TR6. They are 1 step colder, I added extra fuel in the tune to compensate for the hotter plug. I also have at least 20 passes and 7 or 8 dyno pulls and no problems.
J
JayC
674
Southern Indiana
Nov 4, 2005
  • Nov 4, 2005
I've been running a 150 shot of NX for a while now. A good tune, SVT Focus pump, NGK TR-6 @ .035 and -4 on the timing. Results are in the sig
Jay
J
Justin03GT
199
Mount Pleasant, SC
Nov 4, 2005
#10
  • Nov 4, 2005
  • #10
have the edge over what? you've only run a 12.7 and only make 372RHWP...i'm on a 125shot, ran 7.7 in the 1/8th(which is 12.0-11.8 in the 1/4) and make 390rwhp on a mustang dyno...bigger isnt always better...
9
97gtblue
283
pensacola,florida
Nov 5, 2005
#11
  • Nov 5, 2005
  • #11
maybe he spun the tires. or cant shift or has a automatic
BIGGER is better
2kyellowgt
224
Nanuet, NY
Nov 5, 2005
#12
  • Nov 5, 2005
  • #12
Most people I talk to will not go over a 125 shot becuase they dont want to blow there motor becuase they read on the internet that a stock motor cant handle it. So 150 shot will give you an "edge" at the track against the average N2o mustang.
Also I make 390 on a Mustang Dyno, if I ran a dynojet I would be about %15 higher which would put around 430 hp. If you look in my sig you will see my trap speed shows that the car should be in the mid 11's I have serious traction issue off the line and 1-2 shift.
SO :Zip2:
J
Justin03GT
199
Mount Pleasant, SC
Nov 6, 2005
#13
  • Nov 6, 2005
  • #13
i wasnt aiming that at you personally, just making a point that bigger isnt necessarily better...in your case, bigger =less traction and slower times...i myself made 390 on a mustang dyno...but i'm running a compucar kit, which generally result in higher numbers on a 125 than most of the other name-brand kits..
J
Joe Lynch
199
Midland, TX
Nov 6, 2005
#14
  • Nov 6, 2005
  • #14
Centennialstang--Is your car a 2000 GT? Is the nitrous kit a dry kit or a wet one. Auto or stick? Who will do the tuning and how?
The short answer is yes, you can run a 150 shot. But you have a returnless fuel system and you will have a lean spike if some changes aren't made, and it is hard on the engine, even when everything is otherwise perfect.
Joe
CanadaStang
2,093
Mb
Nov 6, 2005
#15
  • Nov 6, 2005
  • #15
I'm just running the 125 shot, as I'm too chicken to try the 150
393W Stroker with Boost - Need Spark Plug Recommendations
  • 387lx
  • Apr 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 30, 2026
HotFox
Free VE Table Corrections — Drop Your MSQ and a Datalog, I'll Do the Rest
  • X-cam34
  • Apr 12, 2026
  • Digital Self-tuning Forum
  • 2 3
2K
Digital Self-tuning Forum Aug 26, 2026
X-cam34
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
  • Gulftown980x
  • Jul 29, 2026
squeak93
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
