T TheButcher Member Jul 16, 2002 39 0 6 Oviedo, Florida Aug 18, 2006 #1 Aug 18, 2006 #1 Hello all. Where would I find a 160 degree thermastat for a 02 GT.
S san~man O-G Founding Member Nov 29, 1999 8,546 3 78 A little grass shack on a big lava rock Aug 18, 2006 #2 Aug 18, 2006 #2 If I remember correctly, 160* was too "cold" and not high enough to get the engine up to proper operating temperature. 180* is your best bet. It's been a long time since I've seen this question so I may be wrong....
DTNODYA Member Dec 15, 2005 831 1 16 Aug 18, 2006 #3 Aug 18, 2006 #3 san~man said: If I remember correctly, 160* was too "cold" and not high enough to get the engine up to proper operating temperature. 180* is your best bet. It's been a long time since I've seen this question so I may be wrong.... Click to expand... +1
stangGT97 New Member Dec 22, 2004 1,299 1 0 Boston area, MA Aug 18, 2006 #4 Aug 18, 2006 #4 san~man said: If I remember correctly, 160* was too "cold" and not high enough to get the engine up to proper operating temperature. 180* is your best bet. It's been a long time since I've seen this question so I may be wrong.... Click to expand... he's running 12lbs of boost, running colder will help prevent detonation. By doing a google search, I pulled up a few places selling a Hypertech 160* T-stat. http://dagostinoracing.com/index.php?main_page=product_info&products_id=11855 http://underbid.com/action/display/item/1050983572/sku/H581011-sk42441.html I'm sure there are more out there
T TheButcher Member Jul 16, 2002 39 0 6 Oviedo, Florida Aug 18, 2006 #5 Aug 18, 2006 #5 Thanks for the help. I'm running a 180 now and with the turbo everything runs a little hotter. I found the hypertech at summit also. Thanks again.
stangGT97 New Member Dec 22, 2004 1,299 1 0 Boston area, MA Aug 18, 2006 #6 Aug 18, 2006 #6 TheButcher said: Thanks for the help. I'm running a 180 now and with the turbo everything runs a little hotter. I found the hypertech at summit also. Thanks again. Click to expand... Didn't even think of Summit. Sounds like a nice setup you have there... any track times?
4 46gtsblown Founding Member Jan 9, 2002 278 0 0 Aug 18, 2006 #7 Aug 18, 2006 #7 Run the 180 if it is running too hot then install a better radiator but stay with the 180deg stat
Purple_Stang New Member Apr 11, 2005 28 0 0 Colorado Aug 19, 2006 #8 Aug 19, 2006 #8 Ya, keep the 180. Change your plugs to the next cooler temp range.
Mike97gt it doe snot Founding Member Jan 26, 1999 10,633 7 89 the people's republic of massachusetts Aug 19, 2006 #9 Aug 19, 2006 #9 the way the stock EEC strategy works 180 is about as cold as you can go.. If you change the closed loop parameters then you can go colder.
