190lph fuel pump on stock 5.0?
p.exeter_bleu
293
El Paso,TX
my stock pump is on borrowed time and im replacing the fuel tank also so i figured i should buy a new pump, is this too much for a currently stock 5.0? will i need a new fuel pressure regulator also? i plan on modding the engine further down the road.
A 190 pump will not be too much for a stocker. You will not need to get a new fuel pressure regulator right now either. When you start modding the motor then you will be one step ahead by having the pump in. :nice:
Also it is a good idea to replace the filler neck grommet on the tank as well.
