I replaced 2bbl carb, plugs, wires, alternator, coil, ignition switch, petronix and solenoid. On the fuel side I had a garage replace the fuel tank and I recently added back a new mechanical fuel pump, but left on aftermarket electric pump as an assist and priming pump with kill switch. The electric pump makes noise as it primes the line but after waiting 30 seconds the fuel gauge levels off and car starts right up. The prior owner has the electric pump wired to accessory on the fuse box 14 amp fuse which also powers my back up lights and turn signal indicator - neither work properly. I thought the mechanical pump would be enough on its own to keep the car running, but it idles better with both pumps running. Is this a clogged fuel line or bad electric pump or both? I have replace the fuel line from the mechanical pump to carb, but have not changed the fuel filter that runs behind electric pump, I didn't replace the fuel tank myself which was done two years ago but would have thought they would check filter and line. The car idles great and gets out of my driveway, but sputters and stalls on the road. If I wait a minute it will restart and I can limp back to the garage. Any thoughts?
