1966 289 Harmonic Balancer torque?
Ford Torque Values
260, 289, 302
Fastener Type Torque Spec
Main cap bolts 60-70 ft.-lbs.
Outer main cap bolts, 35-40 ft.-lbs.
Connecting rod bolts 19-24 ft.-lbs. (40-45 ft.-lbs. for 289 HP Boss 302)
Cylinder head bolts 65-72 ft.-lbs.
Rocker arms 17-23 ft.-lbs.
Intake manifold bolts 23-25 ft.-lbs.
Oil pump bolt 23-28 ft.-lbs.
Cam bolts 40-45 ft.-lbs.
Cam thrust plate bolts 8-10 ft.-lbs.
Harmonic damper bolts 70-90 ft.-lbs.
Flywheel/flexplate bolts 75-85 ft.-lbs.
Pressure plate bolts 35 ft.-lbs.
Front cover bolts 12-15 ft.-lbs.
