1966 Convertible, Back Up Light Issue
  • Thread starter Thread starter Headw8tr
  • Start date Start date Jul 11, 2016
H
Headw8tr
  • Jul 11, 2016
Hello all, new here and just working through threads. I am having a hell of a time replacing a bulb in the socket. It goes in correctly but will not turn into proper position. I have tried so many times that now the contacts on the bulb are scarred. Really? Anyone have this issue? Do I need to change the whole assembly? Really hard enough getting my fingers into the area to turn the bulb so wondering if I should take the whole thing apart.
It's a small and dumb issue I know but could really use a little help. Thanks.
horse sence
8,563
233
Wile Coyote's stunt double
Jul 11, 2016
  • Jul 11, 2016
What happens is the plastic /rubber coating over the wires on the back side gets stiff and will not let the socket push back far enough to let the bulb lock in place .I have pulled on the wires slightly while inserting the bulb and it usually allows the socket to move back just enough to get the bulb to turn and lock in the proper place .
H
Headw8tr
  • Jul 12, 2016
Hey You, Jim, thanks for your advice. Greatly appreciate you reading my post and taking the time to reply. The assembly moves back and forth easily. I did what you said and still have no luck getting the bulb to lock in place. Bulb #1142. Also tried Bulb # 71004 and neither will lock in place.
Fat fingers do not help either. I am no gear head, just a guy who owns a nice car for now. I will continue to play around with it, hopefully I will get lucky. Again thanks for the help. R
RacerJames
165
23
39
Kingman AZ
Jul 15, 2016
  • Jul 15, 2016
It's smaller than an 1156? Mu fuzzy memory is telling me that the marker and backup lights on the '60s cars I was repairing in the early '80s used 1156 bulbs mostly, and the brake/turn bulbs were usually 1157s. The only difference being single or dual filament.
H
Headw8tr
  • Jul 15, 2016
Hi, thanks for your reply. Everything I have searched tells me to use the 1142 bulb. I can get the bulb in, it just won't turn to stay in position.
RacerJames
165
23
39
Kingman AZ
Jul 15, 2016
  • Jul 15, 2016
It's a single filament bulb with two "ears" which are at equal but opposite sides of the brass portion of the bulb, correct?
If so, find an 1156 bulb and compare them?
If you have the power, post pics of the problem, it'll help immensely.
66must
  • Jul 18, 2016
Try putting on surgical rubbur gloves should give you more grip on bulb and coat the base with vaseline carefull not to get some on bulb or fingers
70 Mach 1 Turn Signal Indicator light issue,
  • 70 Mach
  • Oct 19, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
Mach1 Driver
M
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
