T TMVT New Member Mar 19, 2023 1 0 1 Nov 6, 2025 #1 Nov 6, 2025 #1 Hi gents ! Is there a drop in axle to change my gearing from 2. Something to a 3.73 ? I heard axles out of Explorers will work ? What can I use ? Thank you gentlemen.
Noobz347 Stangnet Facilities Maint Tech... Er... Janitor Admin Dude Jan 4, 1985 43,585 21,747 234 Box behind Walmart Nov 6, 2025 #2 Nov 6, 2025 #2 If your is a C -Code then you need ring and pinion gears for an 8 inch rear. If your car is a K or S Code, you need ring and pinion gears for a 9 inch rear. 6 bangers came with some other weird 7 and something. 3:73 for a Ford 8 inch F8RP-Ford 8" / Ring & Pinion Gear Set www.quickperformance.com 3:73 for a Ford 9 inch https://www.summitracing.com/parts/sum-740910 Of course, there are other brands too.
