1968 I6, carb float the cause?
  • Thread starter Thread starter JDS68Stang
  • Start date Start date Sep 17, 2007
JDS68Stang
153
New York State
Sep 17, 2007
  • Sep 17, 2007
Problem started last week, ocassional stalling when stopping at a red light.
Last trip out it started running real rough, then evened out enough to get it home. Now I can hardly get it started, runs real rough, then it will just start running smooth for a few minutes then just stalls out and won't start again.
I checked all vacuum lines, all good and no leaks. Checked for water in gas, that checked out OK, replaced fuel filter since I was at it. Checked around for a short while it was running, nothing.
Does this sound like a sticky float flooding out the engine? Any ideas?
jikelly
20+ Year Stangneter
Jul 9, 2003
872
53
99
Lubbock Tx
Sep 17, 2007
  • Sep 17, 2007
Very well could be. It could also be an ignition issue coil going bad or something.
In that other thread you talked about rebuilding the carb. That would give you the opportunity to fix any carb issues there might be.
JDS68Stang
153
New York State
Sep 20, 2007
  • Sep 20, 2007
Gave the carb a quick cleaning and looked it over, couldn't find anything plugged or clogged up bad enough to cause these symptoms, lowered the float just a hair.
Thought about what you said about the coil, figured might as well replace it along with the points and condenser. Fired it up after replacing the coil, same problem.
Replaced the points (they looked OK, were gapped at .019) and condenser, fired it up again and running great now. Must have been the damn condenser, who would have thought.
Since the car only backfired once during the roughly 10-15 times I was trouble shooting, I thought electrical was likely not it, the flooding out symptoms made more sence, guess you never know.
Thanks for the suggestion, you were right on.
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
