R rustaddict Active Member Aug 23, 2014 218 55 38 Sep 8, 2014 #1 Sep 8, 2014 #1 Is there anywhere on the body or in any paperwork to get the key code information for a 68 Mustang? Specifically the ignition key?
B barnett468 Active Member Aug 1, 2014 179 24 28 Sep 9, 2014 #2 Sep 9, 2014 #2 rustaddict said: Is there anywhere on the body or in any paperwork to get the key code information for a 68 Mustang? Specifically the ignition key? Click to expand... no, however, you can have a locksmith make a key for around $35.00.
R rustaddict Active Member Aug 23, 2014 218 55 38 Sep 9, 2014 #3 Sep 9, 2014 #3 Right. I was just hoping there was a simpler way than loading the car on a trailer and carrying it to town.
horse sence 15 Year Member Nov 29, 1999 12,404 8,328 233 Wile Coyote's stunt double Sep 9, 2014 #4 Sep 9, 2014 #4 You may be able to find a mobile lock smith that can do it where it sits
horse sence 15 Year Member Nov 29, 1999 12,404 8,328 233 Wile Coyote's stunt double Sep 9, 2014 #5 Sep 9, 2014 #5 It would be easiest to remove the key switch and take it to a lock smith. the outer ring spins off the front and the entire switch comes out the back of the dash .
R rustaddict Active Member Aug 23, 2014 218 55 38 Sep 10, 2014 #6 Sep 10, 2014 #6 I can handle that. I didn't figure it would be that easy.
horse sence 15 Year Member Nov 29, 1999 12,404 8,328 233 Wile Coyote's stunt double Sep 10, 2014 #7 Sep 10, 2014 #7 Very simple ,just remove the front ring ,and a 3/8 nut on the back that holds the plugin to the switch and pull it out .
